Performance
Backinblk
I’m sure this has been discussed. But what did everyone do for exhaust to see real number gains? Headers? Y pipes? Resonator delete? I think I wanna do a borla S type or atak.
I mean i didn't see any gain from the intake, moes throttle body, borla atak. I saw a gain from the pulsar, diablosport and even something as simple as running 93 octane fuel
Sent from my SM-G975U1 using Tapatalk
i put a k&n intake on my 2019 ram big horn i dont have numbers but i do feel more power better acceleration and a nice rumble. my next upgrades probably long tubes borla atak exhaust and a diablo tuner when i put them ill comment my exoerience
Cam will give you biggest gains. And a tuner. Intake, long tubes. I used an x pipe and truck loved it. Heads will help after all this other stuff is done.
You may get a good 100 hp off what I stated.
which cam do you recomend? is there a certain brand?
There are a few guys who will grind you a cam. Modern muscle, Greene performance, Texas performance. And I’m sure the list is long. You can talk to these guys and see what they recommend for the type of performance you are looking for. There are different grinds for different purposes and mods and things like that. These forums are full of different guys mods and cams they got. Best to search and see what you can read. Cause there is a lot of info on here.
I added the B2 Fabrications (Moderate) Magnaflow Performance Exhaust. Sounds great but did not realize any performance gains.
I have noticed huge improvement in Performance / Power / Throttle Response from the RAM Airflow however.
At least 30 HP Gain in my opinion, but I do not have a dyno to prove it.
What did the ram airflow run you?
How much was the ram airflow?
Looks like the ram flow sucks air from the upper radiator area which passes through the a/c condenser first... hardly even a "cold air" intake.
I paid just over $900 at my local dealer but I saw it cheaper on Bam Wholesale.
I believe there is a large empty space under that front piece, above the rad/condenser, so that the intake pulls it from in front. However, someone who's installed one would have to confirm that.
Cam, upgraded valve train, LTs , 84mm tb ecm/tcm tuning. Will be a mean ride.
Ugh thats so much money for an intake idk if I can justify that amount lol
Also states “off road use only” so definitely can’t put in on here in Cali (well you could but better keep the original or plan on selling the vehicle when it comes smog test time) until it gets CARB approved
