BeauxXL1200
- Jan 12, 2019
Slight rub on full lock turns, but not enough to bother me. I could trim off a bit of plastic wheel liner to stop it. But again, it’s not that bothersome.Any rubbing?
Air ride?Non-lifted, non-leveled Ram with 285/60/20 Ridge Grapplers. Slight rub on full lock turns, but not enough to bother me.
First time poster, 2 week lurker. This is my 2019 Ram 1500 Laramie 2WD. Just installed the Rough Country 2" leveling kit and some 295/60r20 Nitto's. Its in getting an alignment now, but the drive over was smooth, running currently at 41 PSI. I am thinking that is low since they are max rated at 80psi. Looking at Nitto's website for more info. Anyway, I am loving the look and thought I would share with the rest.
100% no rubbing full turn both directions, no spacers.
Looks good; I have my 2" front and the rear +1" ORP springs in, the 295/60R20 are being mounted friday with a fresh alignment. I have the factory rubber mudflaps.. hope it clears.
295/60/20 ridge grapplers 2” rough country level
295/60r20s on 2020 Ram 4x4 Laramie with stock wheels. Front's rub at full turn only.To be honest, your going to rub the inside of the wheel well if you went with the 295/60R20 on OEM rims. Before I lifted my truck I had the Nitto Ridge Grapplers 295/60R20 on OEM rims and when I reversed and turned to the left, I always heard rubbing. I do not know how it might be on the Big Horn but for the Limited edition is what I encountered. I hope this helps a little when making your decision.
specs? any spacers? lift level?
Sorry for the delay, have not been on the web much. 2" level upfront, Rear has OEM ORP springs (1" taller) but for a box with the Ram Box/Multifunction gate. Little firmer spring in the rear for towing/payload handling. Stock the truck was great to road trip but to soft.. to me it still is pretty soft. Rides great. And there is a 1/4" spacer on the factory wheels just to flush them up more with the factory flairs.specs? any spacers? lift level?
