OEM size: 275/65-18. They are XL rated (116T) and came with 13.5/32" tread depth.And what size ridge grappler are you running? He’s looking at P rated which will be 3/32 of an inch less tread then a LT tire.
Yes, so you have the passenger tire version.... got itOEM size: 275/65-18. They are XL rated (116T) and came with 13.5/32" tread depth.
The Ridge Grapplers are only available in XL or E-rated for 275/60-20. The XL has the same 13.5/32" tread depth that mine do and the E-rated is 16.4/32" of tread (along with a bigger price tag and an extra 12lbs/tire).
Yes. If I still had a 3/4 ton truck I’d go the E-rated route but not for a 1/2 ton. The XL load rating is plenty.Yes, so you have the passenger tire version.... got it
AgreedYes. If I still had a 3/4 ton truck I’d go the E-rated route but not for a 1/2 ton. The XL load rating is plenty.
Which ones are you installing in the morning?That's what I did. My local store didn't have them. I ordered online, install in the morning
Falken AT3W’s are a fantastic tire! Had them on my last truck and was often off-road. They don’t hold rocks and they are quiet. Really good in the snow. They don’t flex and sway in the corners. They are perfect. The only thing is that they are heavy. I sold a lot of sets of them. 99% of customers liked them.Tire distributors at least locally have very little stock. Most are still closed if they are a Tire Center only due to phased re-openings. I don't see how Tires aren't essential, but I'm not a medical professional or a politician so I concede. That said, my local preferred mechanic shop has access to tire distributors and 275/60/20 were rather limited from both distributors.
After searching for tires on my short list and verifying availability I went with the Falken Wild Peak AT3W. My options again were beyond limited, no KO2, No G2's, they had Ridge Grapplers but I really wanted to try something other than Nitto this go around. I'm excited for the Falken's while they weren't at the top of my list they were close and the price was great, much cheaper than the others and the reviews for the Falkens are Fantastic. My Laramie Sport is RC leveled so I hope the Falkens will help fill up the wheel well a little. I will report/picture after install on Tuesday morning.
As Zoompastu said the Falkens that come with the ORP are the Wildpeak A/T3WA which are more of a street tire compared to the A/T3W tires.OEM Falkens are not the same.. gets confusing but the OEM AT3wa is normally sold in Europe and is less aggressive than the AT3w. The AT3w is the one to get.
