Has Anyone Try 2019 RAM Retrofit Headlights?
JDiMassa8
Ohio
Dammit! Thanks for the heads up tho!
You’re welcome. Trust me there’s like 2 or three forums on this exact question and a lot of people wanted to swap over the assembly...me included. The only thing you can do is contact a retrofitting company so they could customize your headlights
Hadaway35
For some reason it would not allow me to add a picture to the chat
I installed all the LED headlights today. I installed the resistors on the wires you had mentioned. And I still cannot get the switchbacks to stop hyper flashing. Did you install one resistor per side. Or did you have to install 1 on the "flashing"wire and one on the "constant on"wire.. I've had switchbacks in every vehicle I've ever owned and none of them have ever been as much of a pain in the ***.
Sent from my MI MAX 3 using Tapatalk
JDiMassa8
Ohio
That’s really strange. I did one per side. I’m gonna gonna have to take mine apart one of these days to double check. I know I did those two wires. Spliced one end into the colored wire then the other into the negative or ground wire.
SB89
i tinted my tail lights and this is exactly what I need! did you need a resistor for it as well?
Nope. Plug and play. Takes 5 minutes for each tail light. Not sure how tints would effect the ouput, but the reverse lights are very bright.
crazy5gen
I see hidretrofitkit came out with new models for our 5th gen 1500. Should i swap the lights to those ? Im planning on getting them but in all black,i love these ones for sure
. Screen Shot 2020-06-16 at 10.26.46 AM.png Screen Shot 2020-06-16 at 10.27.01 AM.png Screen Shot 2020-06-16 at 10.27.10 AM.png
ijanderson29
. View attachment 59201 View attachment 59202 View attachment 59203
Curious if you ever made the switch to these from HIDretrofitkit? They have some pricey options but they look awesome. Also i heard you can send them your headlights and they will take $300 off the cost and turn yours into them.
ZombieSlayer
Oregon
If you send your housing they won't charge you the $1500 for a set. You'll still pay $1K for the retrofit (but you won't have any headlights until they get back :D )
ijanderson29
Luckily I have an extra set of OEM chrome halogen headlights that I haven't been able to sell. Only replaced them with the Night Edition halogens (replaced with LED Bulbs). But ultimately I want a better upgrade so they could have my old OEM halogen's.
