Clyde
- Feb 22, 2020
I’m swapped out my front side dash speakers for Infinity references. My stock speakers were 8 ohm, the references are 4 ohms. I want to add the center dash speaker to my base 6 speaker system.
My thought on how to accomplish this (and get a more balanced system with all channels having the correct resistance) is to run the added middle speaker off one of the side dash speakers in series- making the two speakers a total of 8 ohms on that channel. I would then add a 4 ohm resistor to the other front side speaker also making that channel 8 ohms.
Now my questions for you audio Gurus... any thoughts in general about this set up? Will I achieve a true balance (or close enough), or do I risk one side being noticeably louder than the other or the rest of the system. What resistors should I use, (4 ohm - what wattage, quality brand, etc).
I currently have to fade the balance towards the rears as the ohm difference of the infinity speakers vs stock make them louder. I thought up this idea while contemplating adding resistors to the two front infinity’s to balance it out.
