Cantkilllmetal
- Aug 14, 2019
But I think since you and I have the 6 speaker base system, we need the CH3 harness instead of the CH4 right?Ok good and thanks for the info.
Well I was way off about the harness thing. The CH3 goes behind the radio. Use the ANC bypass on the ANC. Got the DSR1 installed on my truck today and seems pretty awesome. No problems at all. Need to find a better ground for my amps.Yeah I’m pretty sure the 6 speaker system with ANC requires the CH3 harness. This is what Crutchfield and idatalink recommend. If you look at the ANC there are two connectors going into it, which matches the CH3 harness. The CH4 harness has 3 connectors.
I ordered a DSR1 and will hopefully get it installed this week. Going to hook up a 4 channel for the 6x9’s and a mini 2 channel for the 3.5”’s.
Hopefully everything goes smooth. I hear mixed reviews.
Ended up using a pre tapped hole on the back wall behind drivers side rear seat For the ground. M10 1.25. DSR1 is working really well. Had some issues when I had it on high input signal, but maestro and Rockford said to use the low input. Much cleaner, and less noise now.Well I was way off about the harness thing. The CH3 goes behind the radio. Use the ANC bypass on the ANC. Got the DSR1 installed on my truck today and seems pretty awesome. No problems at all. Need to find a better ground for my amps.
