JerryBsizzle
- Sep 22, 2019
Looks great! Sorry one last question, did you have to trim your factory lugs at all for the spacers, or was there enough clearance behind the wheels? Thanks again.
No trimming required. The factory Laramie wheels have pockets between each bolt hole. So the portion of the stud that sticks through the spacer fits in that pocket. I verified this before ordering because I wasnt cutting the studs. Also I didn't want a 2" spacer because that's just too much IMO.Looks great! Sorry one last question, did you have to trim your factory lugs at all for the spacers, or was there enough clearance behind the wheels? Thanks again.
I couldn’t agree more on 2”. I heard the rebel had deep enough pockets, but had heard conflicting on the Laramie stock wheels. I appreciate your responses, have definitely helped make some decisions I’ve been going back and forth on for a while. Again, beautiful truck, and thanks for the inputs.No trimming required. The factory Laramie wheels have pockets between each bolt hole. So the portion of the stud that sticks through the spacer fits in that pocket. I verified this before ordering because I wasnt cutting the studs. Also I didn't want a 2" spacer because that's just too much IMO.
What side steps are these?
Iron Cross PatriotWhat side steps are these?
Any more photos? Angles?Iron Cross Patriot
Any more photos? AnglesIron Cross Patriot
Thanks. Looks great.
