STOKED
Also interested in how you did this. Did you follow a thread on the forum? And are these just amazon LED strip lights?
I used these.
If you remove the rear drivers side door sill you'll see a **** load of wires. Find the white with a tan stripe, thats the cargo light circuit. When you pull the carpet up to get to those wires you'll see a plastic cap in the floor you can drill a small hole through to run the wire back to the bed. It's pretty easy.
dv8er
Las Vegas, NV
Added additional bed lights by tapping into the OEM bed lights after being completely unimpressed with the OEM lighting. Ramboxes made it a little trickier to maneuver the wiring. I haven't attached the light strips with adhesive yet as I only have alcohol swabs (damn covid) and it was getting late. I used a kit that is nearly identical to the one STOKED used. Next will be a couple LUYED backup lights (thanks to you guys for that suggestion) and dashcam install once that gets here.
Truckguy
I used these.
Did you happen to try tying into the cargo lights by taking off the taillight? I think I saw someone else did that. Trying to figure out the best way also how did you splice/tie in?
STOKED
No, I'm not really sure if any of those wires are connected to that circuit as I don't recall the tail lights coming on with the cargo lights. I used one of those crimp slice connectors.
knightro84
Easley, SC
Hey, if you don't mind me asking how did you wired yours up? My gf actually bought me a kit but it wants to be powered the obd 2 which I'm not too sure I like that and wanted to see if there was another method.
I ran the positive from the LED strip and tapped the cargo light trigger wire, which is white with a tan tracer in the drivers door sill, and then used one of the existing ground points under the hood on the driver side fender.
knightro84
Easley, SC
This is what I did - if you have the OEM bed lighting, then you can just remove your tail lights and tap into the OEM bed lights on each side. If you don't have the OEM bed lights, you'll need to tap into the cargo light and run that to the bed. The OEM bed light wiring was super simple - literally red to red and black to black. Here are my pics from earlier in this thread.
YellowSled
West Palm Beach, FL
if you tapped the white with a tan tracer in the drivers door sill, why not tap a existing ground out of that bundle of wires instead of going into the drivers side fender? tks
knightro84
Easley, SC
For the running board lighting - since the wires for the LED strip are outside of the truck, it was easier to just ground it right at one of the existing grounds under the hood instead of having to extend it and run it into the cab through the firewall just to splice into a ground in the loom in the door sill.
HoosierTrooper
Indiana
Added this Carr folding hitch step to save a little wear and tear on me and the bumper when climbing into the bed. Has a nice reflector when closed and might add a little protection if someone taps the bumper.
z0n3
Thos
those strips are bright, what ones are they?
Mustangmike66
View attachment 55089 View attachment 55090
Where did you get your BedRug?
georgelama
Honduras
Got myself a 2020 Granite Crystal Limited since my 2019 Black Limited was received again by my dealer. Didn´t like all the chrome that the limited brought so I decided to invest a little in order to make it look better.
- 22" Limited Black Appearance Wheels
- Painted all the Chrome Grill in Granite/Black mix
- Chrome door trim replaced with black trim
- All "RAM" chrome emblems replaced with black ones (including hood emblems)
- Long door chrome trims removed
- Mirror covers painted matte black
Would love your opinion on what else I can put to my truck!
LamboTexas
Lubbock, Texas
Do they all turn on with the OEM light switch?
knightro84
Easley, SC
Yes, they function just like the OEM cargo lights do. They turn on and off with both the switch in the bed and the switch in the cab.
Thos
I got these: https://www.amazon.com/gp/product/B07KXR799K/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1
It comes with two 60" strips in each package, and I got two packages (two strips for the bed, and one strip for each running board). Might be the best bang for the buck mods I've done yet at pretty much 45 bucks.
Scott_65
SC
Got myself a 2020 Granite Crystal Limited since my 2019 Black Limited was received again by my dealer. Didn´t like all the chrome that the limited brought so I decided to invest a little in order to make it look better. Also you can get color matched mirror covers for about $60 unless you’re loving the black.
Looking good, I would do something with those chrome tow hooks and also maybe tint your headlights and taillights.
dv8er
Las Vegas, NV
I used BedRug part # BRI-BRT09BXK, which is technically made for the older body short bed with RamBoxes. It ended up fitting near perfect. I'm not sure why BedRug doesn't just market that model as being compatible with the newer body with RamBoxes. I got mine on Realtruck.com and chatted with them for a slight discount. Here's the Amazon link for it...
z0n3
Nice, thank you! Did those just easily stick on to the underside of the bed?
