jastevenson
- Oct 9, 2018
Just want to be sure, and the website is unclear.
Possible. Mine is Quad Cab. Could it be that the crew cab's floor storage bins in the rear, (which QCs don't have) restrict the space for the gas tank?Screwing around with the build and price site some more (which, again is not 100% accurate), it appears that the 26 gallon is included w/ Hemi ET on quad cabs, but on crew cabs (depending on trim) it can be optional or not offered at all. So confusing. Sorry for adding to the confusion.
I don't think so, as the 26g tank is optional on some crew cab trims, but not all. You can get a 26g on a Laramie crew for example, but on a Limited the only options are 23g or 33g.Possible. Mine is Quad Cab. Could it be that the crew cab's floor storage bins in the rear, (which QCs don't have) restrict the space for the gas tank?
Sent from my Pixel 2 XL using Tapatalk
At least for the Laramie, I figured it out: if you have a base or Level 1 Laramie, you get 23 gallon tank. If you buy the Level 2 package, you get the 26 gallon. 33 gallon is optional on both.
I think this is still true for Longhorns and Limiteds. But I opted for 33 anyway.FWIW, 26 gallon tank was listed as standard equipment on my build sheet.
