Eticket1337
- May 29, 2022
My sticker shows 22 crew cab, 5.7 bed, etorque with a 23 gallon tank. Bought off lot so no choice.
was in the same boat. two things i don't like about my truck, the gas tank and the gears... gears are easy to change, the gas tank... jury still out.My sticker shows 22 crew cab, 5.7 bed, etorque with a 23 gallon tank. Bought off lot so no choice.
It seems to vary by year, model, engine. As soon as some things are selected, the standard tank changes. Going to the build and price, one of the standards went from 26 to 32, by changing 4wd to 2wd. 32 isn't even an option with 4wd.My build sheet says 26 gallon
32 gallons isn't an option no matter what you order on a 5th gen. It's 23, 26, or 33. 32 gallons was an option on 4th gens.It seems to vary by year, model, engine. As soon as some things are selected, the standard tank changes. Going to the build and price, one of the standards went from 26 to 32, by changing 4wd to 2wd. 32 isn't even an option with 4wd.
According to the build and price, if you build a 2wd I think it was limited and maybe long bed, I don't remember, it says 32. I'm just stating what Ram lists.32 gallons isn't an option no matter what you order on a 5th gen. It's 23, 26, or 33. 32 gallons was an option on 4th gens.
I'm not seeing that. The only fuel tank size option for any 5th gen 1500 Limited (2wd, 4wd, short bed, long bed) is 33 gallon since the 26 gallon tank is standard for that model. The ramtrucks.com website is definitely prone to errors though. Maybe it listed that for a time, but if so it's fixed now.According to the build and price, if you build a 2wd I think it was limited and maybe long bed, I don't remember, it says 32. I'm just stating what Ram lists.
might be because of the 5.7 bedMy sticker shows 22 crew cab, 5.7 bed, etorque with a 23 gallon tank. Bought off lot so no choice.
typo?Model Comparison. Not that it's right.
Wouldn't surprise me. The website sucks. They do list the 33 gallon Canadian tank in British gallons as 27.3 or something, while the 26 is listed in US gallons.typo?
Yeah, the website definitely has issues.Wouldn't surprise me. The website sucks. They do list the 33 gallon Canadian tank in British gallons as 27.3 or something, while the 26 is listed in US gallons.
I would suggest a junkyard. The option is $445, so the parts would undoubtedly cost more. I imagine it takes a different sending unit and tank straps, besides the tank itself.My 2019 Ram Limited 4wd, 5.7 bed came with the 26 gal tank. I use this truck as a tow vehicle and was thinking of swapping out the 26 gallon tank for the 33 gallon tank. Does anyone on here know where to find the 33 gallon tank and about how much it would cost to do the swap and if it would fit?
It has been done by people on here I’m pretty sure there is a post about it.My 2019 Ram Limited 4wd, 5.7 bed came with the 26 gal tank. I use this truck as a tow vehicle and was thinking of swapping out the 26 gallon tank for the 33 gallon tank. Does anyone on here know where to find the 33 gallon tank and about how much it would cost to do the swap and if it would fit?
with your 4X4 it is not so easy to change the gearswas in the same boat. two things i don't like about my truck, the gas tank and the gears... gears are easy to change, the gas tank... jury still out.
There are threads with this information. I priced out the parts a couple years ago and it seems like it was in the $2k range. I ended up trading that truck in for one with the big tank so I never did the swap, but like others have said there are members here who have done this swap and threads with that information. It might take a while to search for them but if you're serious about the swap it's worth taking the time to search.My 2019 Ram Limited 4wd, 5.7 bed came with the 26 gal tank. I use this truck as a tow vehicle and was thinking of swapping out the 26 gallon tank for the 33 gallon tank. Does anyone on here know where to find the 33 gallon tank and about how much it would cost to do the swap and if it would fit?
gears don’t worry me as much. realize it’s not the same as live axle gear swaps.… the tank does. i’ve seen some talk about guys swapping tanks but i hadn’t researched it too much. need towith your 4X4 it is not so easy to change the gears
last i heard the front is not available
lots on the forum have changed the tank
