Finally scored both Rebel tail lights on ebay and got them installed today. Been watching since last summer when I cracked one of mine, finally found them both a couple weeks ago from two different sellers.
Kind of a before and after, I took the pics after I got one swapped. I wanted to test drive it after one was replaced because I heard something about the PCM might not like a different cross path detector and give you a warning or code. Then you would have to calibrate the sensor. I had no trouble with either of them, but I haven't actually tested the cross path, only the blind spots.
l like these lights alot w/ the black accents ... would have liked these on my limited much more than the straight red tails ... good improvement ...
Can you link me to them? I can't even find them on Amazon, I can only pull up the ones for the quad cab
I guess I got the last one, they don't show it as an option now.
ebay has it for $132 w/ free shipping ...
Is this all that's needed to install for trailer towing? I'm looking at getting a small trailer to tow and trying to figure out the cost of getting the Ram tow ready. What about the switch that goes on the dash?
I had pieced together what I was told I needed and it was like (4) pieces.
Just installed
Fuel Rebel 20x9x1
Bfgoodrich 285/65r20 ko2
Looks badass!! what do you have for a lift and any rubbing?
this kit includes l believe all you need ... dash switch, controller, controller bracket and hardware....great price for this kit ...
Has anyone purchased this exact kit offhand ? I don’t want to buy and then find out now I need three more parts that I have to scrounge around for please. :)
Installed Redline LED tailgate lights. The space to mount is not flush, i.e., tailgate harness cover, so I used spacers. The two ends near the taillights are angled. wtf. Did anyone build the ends up to mount the lights on? Thanks. Special thanks to dts828 for your guidance!
there was a video of someone here on the forum that did an install and listed the parts needed ... this should be a complete kit ...
Got my Hellwig sway bar installed today!
Just did a test drive and I’m already impressed. Truck handles so much better. I have it set on the medium setting.
  • Back
