Taegee2
VA
Go Rhino RB20 here with the bedliner coating (one of few running boards out there that gives you the bedliner option...you could always get them sprayed aftermarket like line-x for about $150) I got them back in the fall of 2019. Took about 6 weeks to get them from Go Rhino. Seems like they are always out of them or back ordered but worth the wait. Definitely spend the extra $$ and get the bedliner coating instead of the standard powdercoat. Don't have to worry about the powdercoat paint scratching and wearing off causing them rust. This stuff is solid and so far I like them a lot.
Ramjeep
Running board and window deflectors. I couldn't leave well enough alone and ended up breaking the passenger side one. Have to get a new one next week.
5thGenRebel_AMK
PA
Got my truck washed for the first time in a couple months. All the self serve car washes around here are shut down. Also applied some turtle wax ceramic spray coating.
super jealous you fit in your garage, mines like 2 inches too long... on paper it should've fit according to the blueprint of the house
Taegee2
VA
Same here...Truck too big to fit in my garage. They don't mage garages like they used to. Make them for compact car nowadays and barely wide enough to open the doors on one side only.
JInWA
2019 Ram 3500 6.4L Hemi
Pearl Blue Streak
Reg cab Bighorn
Single rear wheels
Combination type 1 and Type 2 (ordered prior to packages being set)
Clearance lamps
LED lighting
Rear retractable step
Today finally ordered the add on’s that were supposed to be on the truck the day it was delivered. The retractable steps and fender flares. Also ordered a Soft Topper
onelochevy
Slidell, Louisiana
Motofab 2.5" leveling kit installed. Now to convince the wife I need some new wheels and tires
Waterfowler41
Chicago
Quarantine boredom inspired video on my channel of the B2 tips from chrome to black.
Stay safe everyone...
Redwings1391
Ordered ridge grapplers to sit on 20x10 fuel vapors, rough country leveling struts, all the parts for. 3.92 swap and a cat back corsa exhaust with resonator delete pipe. Needless to say this time next week it’s going to be a different truck!
Mustangmike66
The truck is looking sharp. I’m liking the red calipers. I may have to do that.
