2020 REBEL ED GRILL COVER?
Wrecktal
Anyone know where I can get a grill cover for my rebel? I live in AK. The dealership is saying that it doesn't exist.
2019REBEL
ON, Canada
Did you get the cold weather group as the cover is part of that group. Maybe see if your dealer can find one that has this group and order you one. They do exist.
Wrecktal
I did get the group. Didn't come with it. Says that the part doesn't exist. I've looked through the mopar catalog and it doesn't exist either.
Sent from my LM-V450 using Tapatalk
2019REBEL
ON, Canada
Maybe US and Canada different but Canadian ones have the Grille cover. I talked online with this dealer and it definitely comes with the cover. Presently working until Friday so can't check my local dealer but will see if they have one on the lot.
COLD WEATHER GROUP -inc: Winter Front Grille Cover
Even put that VIN into the equipment listing and it lists the cover.
rorischak
Pennsylvania
Mine came with it and It was also under the rear seat. You should have gotten it with the cold weather package.
M1STTRS
Michigan
Sorry I have the longhorn trim but I don't think that should matter.
how wouldn't that matter? Rebel has a different grill than all other models of ED which explains why there isn't a grill cover. Because they didn't make one.
Sascwatch
They are available and I have one for my rebel. It requires you to order the cold weather group.
Sascwatch
That one doesn’t look anything like the cover that came with my rebel. I’ll take a picture of it tonight and post it here. I don’t remember seeing any part numbers on the cover I got, it was -28 when I opened it and installed it so I probably just didn’t notice one.
biodiesel
I ordered my truck with the cold weather package. I'm in northern New Mexico where the temps don't get cold often, but I've seen -17*F with daytime temperatures no warmer than 27*F. What ambient temperature would you recommend putting on the cover?
Sascwatch
With active grille shutters you might never need to use the cover at those temps. Around here most people put them on below -10c, but I’ve ran highway speeds at -25c and had no issues as the shutters closed.
biodiesel
-10c = 14*F
-25c = -13*F
Wow, that's pretty cold for not needing a cover. I figured the engine could use some help from the cover with temperatures under 20*F (-6c). I probably should look in the owner's manual to see if it gives any recommendations.
WillyDubs
Can someone install the winter front on their Rebel for me to see it? I have the winter package and the Rebel didn’t get a winter front
Skenth
Here's my 2020 rebel with the cover on it. Its a bit wrinkled as it was stored under the seat but should stretch out
