Jayturk
Just got my Truxedo stake pocket hole covers, they snap in, smooth finish. It came as a set of four, if you're looking for a pair, I have two.
You’ll love those wheel well liners as it cleans up that area.
Interested in the 2 you have ....Just got my Truxedo stake pocket hole covers, they snap in, smooth finish. It came as a set of four, if you're looking for a pair, I have two.
What liners? Link please.
you should already have them on your limited....
I do thxs! Always scratching for more mods.
Do you have any more pictures? Maybe some during the daytime
I went with OEM that I got off Ebay. But I had to cut to fit right. Not real hard. I did use soap water and alcohol.Very nice. I need to order a set of the bedside decals for mine. Did you go OEM or aftermarket? I’ve seen some on eBay but they are not the exact same size.
And how hard was installation? You use a bit of soapy water to apply them?
Thanks!
I got oem off Ebay. Had to cut to fit . Yes I used water soap mixtureVery nice. I need to order a set of the bedside decals for mine. Did you go OEM or aftermarket? I’ve seen some on eBay but they are not the exact same size.
Thanks!
Not yet. I will post someDo you have any more pictures? Maybe some during the daytime
I placed an order for the lights and tape at Amazon. The tape will be here tomorrow but the lights don’t ship until April 22Use the thin 3M tape and cut down the plastic edging for 90 degrees curves. The panels are super easy to remove if needed. Have fun!!!
View attachment 51037View attachment 51038View attachment 51039
I recently traded a Lariat that had color changing accent lighting; blue with the doors closed and red when the doors opened. Probably my most favorite interior features on the truck, and I miss it every time I drive this new Ram. I think you may have helped me with a solution. Thanks for the share. I was just about to pull the trigger on the Ram logo LED cup holder inserts before I saw this. The Amazon reviews mentioned a loud noise from the driver. Have you noticed that with your lights?The OEM accent lighting on my Limited is pathetic. I like the lighting in my 2019 BMW X5 a lot and this lighting mod resembles it.
Which model# AVS hood protector did you get?Also added the new personal plate, hard tonnrau cover and aeroskin bug deflector.
Where did you start the wiring?I'll take some daytime shots today. I used the thin size 3M double sided tape on some places. I actually replaced it last night from the 9ft to the 16ft to be able to fully wrap around the center armrest console. I will also install the 9ft tonight. The installation is kinda fun.
Here's the listing for the 16ft:
Amazon.com: San Jison USB Neon EL Wire 5M/16FT for Xmas Party Decoration Pub Festival Decoration Glowing Electroluminescent Wire Light Cold Lights String Strip(Blue): Automotive
Buy San Jison USB Neon EL Wire 5M/16FT for Xmas Party Decoration Pub Festival Decoration Glowing Electroluminescent Wire Light Cold Lights String Strip(Blue): Rope Lights - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
Here's the install last night:View attachment 51033View attachment 51034
