Beastram
Anybody having issues with it not clapping down tight with the factory
Mine does seem a little loose. It looks like I have a gap, but when I check, there does not seem to be a lot of water coming in.Anybody having issues with it not clapping down tight with the factory
Right. Same here, I can blast it with the water hose and it's surprising how little water gets in. Pretty impressed.Mine does seem a little loose. It looks like I have a gap, but when I check, there does not seem to be a lot of water coming in.
Dan
Yes that’s how mine isMine is not right at all when you drop the tailgate you can see air gaps everywhere
It's going in tomorrow to start the processWhat did you do about it
Update: With all four clamps relocated to the tightest possible spot in each corner, I had a highway drive, 75mph and 50mph cross wind... it lightly flapped like my velcro Truxedo, but did not come loose or move at all. For all of you with loose Trifolds, I highly suggest moving your clamps. I'm actually thinking of ordering 2 more for the middle... way stronger than just 2 at each end.
Can you post a picture of your setup if possible?Update: With all four clamps relocated to the tightest possible spot in each corner, I had a highway drive, 75mph and 50mph cross wind... it lightly flapped like my velcro Truxedo, but did not come loose or move at all. For all of you with loose Trifolds, I highly suggest moving your clamps. I'm actually thinking of ordering 2 more for the middle... way stronger than just 2 at each end.
Thanks for posting these!No problem... So, tight seal on top, front to back...
Clamp location close to cab...
Clamp close to tailgate...
No problem! Remember to move the ones by the tailgate, you have to completely take apart the last section of the cover.Thanks for posting these!
Mine ripped off and damaged the bed while driving down the highway
