Tonneau cover
Neurobit
RAM Sorcerer
Texas
Anybody having issues with it not clapping down tight with the factory
No issues here. Had mine for two months.
The tonneau itself is not super tight, I can make it shift a little if I put some muscle into it, but the clamps themselves are tight.
Neurobit
RAM Sorcerer
Texas
Mine does seem a little loose. It looks like I have a gap, but when I check, there does not seem to be a lot of water coming in.
Dan
Right. Same here, I can blast it with the water hose and it's surprising how little water gets in. Pretty impressed.
Aries Ram
AriesRam
Alabama
Mine is not right at all when you drop the tailgate you can see air gaps everywhere
riccnick
Southwest Florida
Picked up my truck this weekend and noticed my cover is barely held in place with all the clamps on. Seems like they need another 1/4" to clamp tightly...
Spirito2
Mine ripped off and damaged the bed while driving down the highway
VaderRebel
Canada
I took apart my soft trifold and moved all the clamps, the rear especially, closer to the tailgate. Moving between the dips above the tie down rail (pics can be provided) the sticker says NOT to clamp on to. It's perfect, snug and I haven't seen a drop inside, two significant rainfalls since fixing. I really hope Ram engineers read this forum.
VaderRebel
Canada
Update: With all four clamps relocated to the tightest possible spot in each corner, I had a highway drive, 75mph and 50mph cross wind... it lightly flapped like my velcro Truxedo, but did not come loose or move at all. For all of you with loose Trifolds, I highly suggest moving your clamps. I'm actually thinking of ordering 2 more for the middle... way stronger than just 2 at each end.
Neurobit
RAM Sorcerer
Texas
Thanks. I’ll remember this just in case. Mine fortunately are fine at factory location, but I will keep an eye on it.
Cheers,
Neurobit
RAM Sorcerer
Texas
Can you post a picture of your setup if possible?
Thanks!
VaderRebel
Canada
No problem... So, tight seal on top, front to back...
Clamp location close to cab...
Clamp close to tailgate...
Ksilva211
Where can you order additional clamps?
