I think most ceramics youd want to apply them inside a garage. Who knows what would happen to your truck if pollen, or a sudden rain storm hit while applying it. Yikes!
That's why I did mine in the garage. Front half then rear half. No rain in forecast and was a hot sunny day to cure the coating.
Finally got her back after a month..
Color matched the grill
Black tow hooks
Factory black window trim
Rough country light bar
70% ceramic on the windshield
Front/rear dash cam
Replaced all the speakers with Skar audio speakers (amp and subs pending)
Look awesome
I added a weatherguard toolbox, and bullring tie downs.
Black tow hooks
Front/rear dash cam
Did you use the silk-dome Skar speakers?
How are they compared to the other ones?
Not sure exactly which model they are, but they are sharp, loud and clear without an amp
Model SK69
I haven't heard the others
Model SK69
Oh I thought you did the dash speakers...
I saw a limited for 49k so now all
Limited’s look expensive. Think the one I saw was a 19 though. Not a fan of the all blacked out rams though so to each their own. You’ve made some good mods to that truck.
I just picked up my limited almost 2 weeks ago now for $46,700 down from the $66,045 msrp.
They had the price advertised fairly aggressive for about a week prior. Went straight to the epicenter in Washington.. Kirkland
They did swap all three out but I'm not sure which model they used
Yeah. I have a carport, but no garage. Going to hang some plastic to help close it in and I plan to do another clean/wipe down on each section as I go.
Start early b/c it has to cure. Or, if you're in a hot climate with direct sun after you've completed the application, that will help cure it.
  • Nels
