OPT 7 Redline LED Tailgate Bar & Window Tint
Bootleg
Figured I'd join in on a couple of simple modifications Went with the OPT 7 Redline Triple LED bar and got the front windows tinted to match the back. With all the rain here, I haven't been able to get her washed in almost 3 mos.
Truckguy
Where did you buy the LED bar?
Ellisstrong
Atlanta Ga area
I installed this same light bar last weekend.
19TXLimited
Do you have pictures of how this mounts to the rear with the lights off? Interested and pricing doesn't seem bad at all for this.
2019REBEL
ON, Canada
Post 25 shows mine off.
dts828
Atlanta, GA
Here a few pics of the mounting:
dts828
Atlanta, GA
How did you clear your tailgate with that big of a spacer?
Don't believe you can go with that much smaller of spacer to clear the covers(or whatever the plastic is) in the middle, I used 1/4 " spacer in the middle and 1/2" spacer on the ends, you need to position the light bar as low as possible. Basically the bottom row of led's is flush with top of bumper.
Ellisstrong
Atlanta Ga area
Yours looks like it is almost sitting on the bumper is it?
ppowell1983
I hooked up the same light bar last week and mounted it the same. But I wired the reverse light part to the bed light switch on the left side. Now I can turn on the white light anytime from the cab, even when driving forward. Coolest feature ever.
19TXLimited
Red or Amber to match the truck...sorry I'm being lazy here and don't want to walk outside and apply the brakes, etc. to check.
MValdez
North Wales, Pa
I installed mine months ago and be aware when opening the tailgate has a tendency to slightly rub the light bar and will scratch paint
2019REBEL
ON, Canada
That's the main reason I went 48 inch no spacers so it doesn't stick out and rub the tailgate.
dts828
Atlanta, GA
If installed correctly a 60" opt7 light bar CAN be installed with spacers and NOT rub the tailgate. It's not rocket science, plenty of people on the forum have done it.
