rrbhokies
- Jun 8, 2019
So my question is a little different. I know a lot of people like me that are running the Bridgestone Duelers just have sh#tty tires. But others have replaced them with various other brands and sizes, and from I think I'm hearing, they are all having similar issues. If it's the tires, how come it seems to be every single tire by every manufacturer out there that is having this problem and requires the surgical precision of a brain surgeon with a degree in rocket science?I would ask these questions...
1) Does your shop use low taper collet adapters on your balancer?
2) Do your technicians back cone with those collets 100% of the time?
3) Does your shop have and use pin plates 100% of the time?
4) Do your technicians perform a center check to ensure a properly mounted wheel to balancer?
5) Do your technicians perform a check spin after wheels weights are applied?
6) Do your technicians correct for residual imbalance? If so how? (On a Hunter machine turn Smartweight OFF)
7) Do your technicians check and correct for Static and Couple imbalance to under a .10oz? If so how?
8) Do your technicians ensure wheel fits tight to hub bore on car? If doesn't do you offer hub rings as a solution?
9) Do you road test vehicle after tire installation?
There are a few more questions like too little or too much tire lube when mounting. Too little tire lube and the tire may not seat correctly. Too much tire lube and the tire can move on the wheel and that will mess up your balance work. Are they re-using wheel weights, it's a horrible practice but some shops do. When have they calibrated their machine and how do they know if calibration was good. Are the cones/collets worn out or are they in good shape. Have the shop technicians been properly trained to operate equipment correctly and do they have the knowledge and skill set to correct imbalance. If so how do you know.
Here are links to the proper collets and pin plates I am referring to.
Wheel Balancer Accessories | Coats
Find high-quality wheel balancer parts for your needs at Coats Company. Shop online with ease for reliable and precise accessorieswww.coatsgarage.comDouble Sided Low Angle Collets, 40mm (set of 8) covering range from 2.04"-5.30"
Double Sided Low Angle Collets, 40mm (set of 8) covering range from 2.04"-5.30"www.coatsgarage.com
Also attached are some Bulletins that discuss proper collets and mounting. They don't address pin plates which is really stupid on their part. They do discuss RFV but unfortunately place more emphasis on this than the most common causes and corrections.
I know a lot of information... Hope this helps even one RAM owner!
Thanks
I mean, at the end of the day, isn't it simply the damn truck? Otherwise, I would glady toss the stock tires (and rims) and go get me some Nittos with bad-*** rims, and call it a day, but if a several thousand dollar investment in new tires/rims still requires me to weed out the one shop in my state that probably has the equipment and knowledge to do everything you've laid out here, then to hell with it all together, I'm just going to get rid of this POS!!
I mean please, someone tell me my problems will go away if I order a set of Nittos and some new rims!!
