285/65/20
Bobbybl30
19 ram 1500 4x4 no air suspension. 2” strut lift. Will 285/65/20 fit? Stock wheels
I think you would be fine. My truck is not lifted or leveled and the Nitto Ridge Grapplers i put on stock wheels work fine. Slight rub at full lock turn of the steering wheel in reverse. But not enough to bother me. And you’re lifted.
You have 60's, he is asking about 65's. Big difference.
285/65/20 Fit my Off Road no problems which is 1 inch above stock. My only rub was on full lock in or out of a driveway. I do now have the Mopar lift which is 3'ish above stock.
Great looking truck! I’m looking to do your exact setup soon with the 2” motofab and KO2s. Would you make any changes hindsight or are you really happy with this setup?
Thanks im really happy with this setup no issues but maybe later on im going to add/switch another upper control arms just for safety.
Yea that was my next question if you did anything with the UCAs. Thanks, good to know.
285/65/20 nitto grappler rubs a little in reverse at lock but I will be adding a bilstein 5100 to front for level may do bilstein for back [/IMG]
Stock wheels, or have you changed offset?
How does your truck ride with the level and those tires? I really like how it feels stock but planning on going with similar setup to you.
Ride like stock after leveled only notice a difference with heavier tires on it feels little slower but problem fixed with a cold air intake installation.
Any update after you did the 5100? I’m about to do the same thing with the same tires want to be sure they fit good.
