285/65/20
Bobbybl30
19 ram 1500 4x4 no air suspension. 2” strut lift. Will 285/65/20 fit? Stock wheels
BeauxXL1200
I think you would be fine. My truck is not lifted or leveled and the Nitto Ridge Grapplers i put on stock wheels work fine. Slight rub at full lock turn of the steering wheel in reverse. But not enough to bother me. And you’re lifted.
JerryBsizzle
You have 60's, he is asking about 65's. Big difference.
Atretes1
285/65/20 Fit my Off Road no problems which is 1 inch above stock. My only rub was on full lock in or out of a driveway. I do now have the Mopar lift which is 3'ish above stock.
Dynamite
Texas
Great looking truck! I’m looking to do your exact setup soon with the 2” motofab and KO2s. Would you make any changes hindsight or are you really happy with this setup?
Thanks im really happy with this setup no issues but maybe later on im going to add/switch another upper control arms just for safety.
CaptShred
Yea that was my next question if you did anything with the UCAs. Thanks, good to know.
busa2009
Atlanta, Ga
285/65/20 nitto grappler rubs a little in reverse at lock but I will be adding a bilstein 5100 to front for level may do bilstein for back [/IMG]
Eltaco
Stock wheels, or have you changed offset?
Dynamite
Texas
How does your truck ride with the level and those tires? I really like how it feels stock but planning on going with similar setup to you.
Ride like stock after leveled only notice a difference with heavier tires on it feels little slower but problem fixed with a cold air intake installation.
