I think you would be fine. My truck is not lifted or leveled and the Nitto Ridge Grapplers i put on stock wheels work fine. Slight rub at full lock turn of the steering wheel in reverse. But not enough to bother me. And you’re lifted.19 ram 1500 4x4 no air suspension. 2” strut lift. Will 285/65/20 fit? Stock wheels
Ah. Sorry I missed the “65”. My bad.You have 60's, he is asking about 65's. Big difference.
Great looking truck! I’m looking to do your exact setup soon with the 2” motofab and KO2s. Would you make any changes hindsight or are you really happy with this setup?285/65R20 Stock Wheels 2 in level
No issues, no rubbing or trimming
No Air Suspension/ No Off Road Pkg.
View attachment 46881View attachment 46882
Yea that was my next question if you did anything with the UCAs. Thanks, good to know.Thanks im really happy with this setup no issues but maybe later on im going to add/switch another upper control arms just for safety.
285/65/20 Fit my Off Road no problems which is 1 inch above stock. My only rub was on full lock in or out of a driveway. I do now have the Mopar lift which is 3'ish above stock.
I changed wheels. Wheel info in signature.Stock wheels, or have you changed offset?
How does your truck ride with the level and those tires? I really like how it feels stock but planning on going with similar setup to you.285/65R20 Stock Wheels 2 in level
Any update after you did the 5100? I’m about to do the same thing with the same tires want to be sure they fit good.285/65/20 nitto grappler rubs a little in reverse at lock but I will be adding a bilstein 5100 to front for level may do bilstein for back [/IMG]![]()
