What's the best bed step functionality option?
smashweights
D-Lux Apt In the Sky
You won't regret it. Just ensure you have a ratcheting torque wrench and a shallow socket (i believe 15/16"). The only difficulty with the install is the space between the exhaust and the step is tight and you can only get about 1/4 turn or less. I tried to do it with a beam style torque wrench, which was nearly too wide to fit, and it took ages until my neighbor popped over to see what I was doing, offered me his cheap harbor freight ratcheting torque wrench and it was waaaay easier.
jloops
Florida
Wow, thanks guys!
Lots of replies, but one recommendation lol. I will go with Mopar step then!
Where can I get the best deal? BamWholesaleParts seems to be back ordered.
Local dealer might be the way to go with the 15% off coupon. Also compare to MoparAmerica they used to have good deals on them and always had them in stock.
cj7
MD
I put in the bed step as well. If you want to have an assist with the tailgate down i think it is the best option. There is a 20% off any accessory coupon on the Ram website as well
Where might this 20% coupon be found?
Kooch80
Washington
  • Like
Reactions: cj7
Sv250
Keep checking ebay. I got mine for $280
Bubba33
I believe I used big have half in adjustable handle to tighten it with a extension. Didn't use a torque wrench. Just got it real tight.
smashweights
I'd probably check it with a torque wrench at least. Install recs 120ft-lbs and two of the bolts hold the trailer hitch.
Kelan
Found it for 21% off = $263.55 + free shipping with code "FREESHIP" ...I'm about to order one myself.
mikeru82
The Palouse
For anyone with aftermarket 5 inch exhaust tips, remove the driver side exhaust tip before attempting this installation. I wasn't able to install my step with the B2 Fabrication exhaust tip in place. Might have been able to force it, but I didn't want to scratch the tip up. I'd probably remove the stock one if I was installing this step again. It's easy enough to remove, and gives you a lot more room to work.
TVANVA
Lynchburg, VA
Found it for 21% off = $263.55 + free shipping with code "FREESHIP" ...I'm amount to order one myself.
Thanks for the tip. Price and coupon was still valid, so ordered one for myself.
Nibis
I got mine installed yesterday, besides slipping off the lower nut and busting, and cutting my knuckle on the spare tire shield, it a pretty easy install, and, I love it !
curh
Anyone know why this part shows discontinued most places?
