2019 Ram 1500 Lonestar Grinding noise when turning Right or Left at medium to low speeds.
ProdigyDude
@ 20k miles it started making this grinding noise (like something is rubbing) when making sharp right turns. Now @ 23k miles and it’s making that same noise. You can see in the picture it looks like the the lower control arm is making contact with the steering knuckle(correct me if I’m wrong).
Hi ProdigyDude,
If you decide to address this with your dealer, please be sure to let us know via private message! We are more than happy to provide you with an additional layer of support for that process.
Mark
RamCares
Same issue here..both side...2020 Ram Bighorn only has 1200 miles....
Wow only 1200 miles. Do you also hear the noise when turning left or only right? Let me know if you take it to the dealer.
Definitely taking it in. No reason is should be doing that. I only get the popping noise when turning right, as I’m going over a bump. Never really hear the grinding.
Hi ProdigyDude,
Mark
RamCares
I have the same issue you think you can help me
Greetings Arroyorebel,
We'd be happy to help. Please follow up with us via private message to provide additional details regarding your concerns so we may determine how to best assist you.
Rob
Ram Cares
Rob
Ram Cares
I contact fca and they said its normal when my truck its to much
Anyone get a resolution to this from the dealer?
I experienced a grinding noise as well and it was caused by the tires making contact with the plastic wheel housing cover when turning the wheels. When the dealer applied the underbody rust protection the hot grease melted the plastic wheel well and twisted it out of position. The dealer replaced the covers and the noise went away.
