RebelWraith
Polymath
Yes, the LED boards are replaced and some extra wiring is put in to control the RGBW color changing and effects.Did you have to open up the headlights to do this?
What is the build date of your RAM?What did i do? Took out the back seat (40% seat and left in the 60%) for alittle more storage room. Dont wanna turn it to a rant fest, but found some stuff wrong (back window channel cracked and radio issues) that kinda bursted my bubble -_-
February 5, 2019What is the build date of your RAM?
	You got any pics of your truck straight on from the front and straight on from the back? Thinking of blacking mine out similar but slightly different than the OEM lookFirst wash yesterday
Truck looks amazing - more pics!Fresh new set of wheels and entire truck ceramic coated![]()
Dang that's clean!Fresh new set of wheels and entire truck ceramic coated![]()
Wheel info please...guessing 4wdFresh new set of wheels and entire truck ceramic coated![]()
What wheels are those? Size? Offset? Do they stick out past the fenderwell or rub?Fresh new set of wheels and entire truck ceramic coated![]()
I have the same light bar, could you add a few pictures of the wiring? love the way they turned out.
Thanks! I suffer from an illness. I think I can do anything but lack the basic skills to do it. This is a huge helpHere are the pix. The 1st is how I originally wired but the Light Bolts only worked w/ the white driving/spot light. So I re-wired, using the Logisys remote and simply tapped into the 30 A fuse for the RC Light Bar, before the Light Bar's switch.
Wheels and tire is sexy as hell. Good job bro!Fresh new set of wheels and entire truck ceramic coated![]()
No prob's! I'm a bit of a "too many thumbs guy" myself and sometimes have to get my upgrades fixed by pros. This is easy-peasy and the Logisys is the way to go so you can have these Light Bolts on anytime that you want. Good luck!Thanks! I suffer from an illness. I think I can do anything but lack the basic skills to do it. This is a huge help
thankswheels look like 4play 4p08 Brushed Black ... 22x10 -24 offset ... l love the 4play wheel line ...
