ProComp 6" Lift - Teaser Photo
I Love Grits
5thGenRams Supporter
Posted to their Instagram on 6/25/18 with caption "...This should be hitting stores soon."
6" lift with 37" tires on 20" wheels.
I canceled my readylift order so that I could jump on something like this. Can’t wait for a kit to be available
I hear you. I'm holding out for a 4" with 35"s. The factory rake is killing me though - its getting harder and harder to not get a small leveling kit in the interim.
The factory Rake is HORRIBLE!!! paired with the fender flares and tiny wheels I can’t hold off much longer either lol but it’s so damn comfortable to drive that I am enjoying the smooth driving Before the meaty tires arrive...
Nada. I wonder if they'll have it ready for market by SEMA (end of October).
Looks amazing! Not sure I could get my newly-ordered Longhorn in my garage with a 6” left though. Just purchased a 2019 longhorn yesterday and the Ram dealer’s aftermarket specialist told me that “a software module is not available for the 2018’s or 2019’s so 35s are not compatible with anything after 2017 models”. Yet I’m seeing so many 35s on 2018/2019 models. Am I missing something? My truck is will take 4 to 6 weeks to build and I hope I might have an option for 35’s. HELP!
Plenty of people are rocking 35s. I've got 34s because I didn't get the 3.92 gears. He may be referring to the speedometer. I couldn't get the dealer to reprogram it for my 34s and they said they couldn't do it for the last two years. I just have to be mindful that it is off.
Hypertech does have a compatible tool out that will reprogram tire sizes for the 2019s.
Thanks so much for sharing that. I’ll look into Hypertech. Do you know if your warranty is voided if something were to go wrong with your drivetrain or otherwise? Also, I do lots of highway driving so I opted for the 3.21 not knowing that the 3.92 would/might be best. Any idea how significant these differences would be regarding ride or even fuel economy? Thanks again!
From what I've gathered, even with the 3.21 gears, 35s should be fine thanks to the 8 speed transmission. The 1st gear is low enough that it shouldn't feel sluggish. You may have a little bit of gear hunting at highway speeds with 35s, between gears 7 and 8. You can negate that by only allowing it to go into 7th gear with the gear limiter. Tbis also turns off the MDS. If I could go back and buy my tires again I would get 35s.
As far as the warranty, the Moss Magnuson act protects you. The dealer has to be able to prove that the modification caused the failure. Even then, the bigger lift companies warranty their product and your drivetrain if it is found out the lift does cause the problem. I dont know that I'll go with a 6" lift, but I will probably go with at least a 4" when more options are available.
Fuel economy is going to take a hit regardless. With 34s I can still get 18-19 on the highway. 35s I would imagine another 1-2 mpg drop. Ride quality should still be good. It will be stiffer but more so because of the stiffer tires than anything else. I've got 275/65 BFG KO2s and while it is a little rougher, it is not bad enough to bother me at all.
Thanks again. I’m Not familiar with the gear limiter but considering that I drive more than 30,000 miles a year and 90% of it is above 60 mph to lose my eight gear might be a dealbreaker. I wonder if I had 34s not familiar with the gear limiter but considering that I drive more than 30,000 miles a year and 90% of it is above 60 mph to lose my eight gear might be a dealbreaker only assuming that cruising in eight gear would deliver the best fuel economy. I wonder if I had 34s if the appearance and rare-occasion off-road’ing performance might be more than satisfactory yet what deliver great fuel economy considering.
34s appearance and performance wise are plenty enough. Like I said that's what I run, and no issue whatsoever. 35s may or may not have the gear hunting, experiences seem to vary. Here's my truck leveled with 34s to give you an idea of looks.
Looks great! What rims are you using? I like them.
the readylift kit is 3.5 and fits 35s well
Any Updates?? I don't think I can hold out much longer lol...
I need 6 inches and 37's or BUST for this build!!!!
Im bored of stuffing 35's under my ram lol
I saw this video posted on another site about the Pro Comp 6" lift - it is still just "coming soon" but here is some more visual candy for you.
I emailed them about 3 weeks ago and they said it won't get released until around SEMA....so that's going to be the end of October, early November
Dang.... emailed them yesterday and they said no eta yet. Cant wait that long! Ughhh
