bigoldthor
Southwestern Indiana
Today, the dealer is installing the OEM step tubes and applying the Simonize treatment. Will post pics once it's done and I have time.
Livinfast85
Pearland Texas
Just added the Chrome Grille Overlay today...
And a few days ago added some ambient lighting on the dash
Do you have a link for the lights you used for the ambient lighting?
rzims
Can’t wait to install these tomorrow!
Ok, probably a dumb question, I apologize in advance......what is the purpose of airbags? I've seen them on HD trucks for towing, but don't know why they are installed on a half ton? Is it for towing or just raising the truck?
MannymanX
5thGenRams Supporter
AzZona
Yes sir!
Livinfast85
Pearland Texas
They are for towing. I have them on mine also.
Rustin5
Got this in. Dog approved
SColang22
Towing. Our trucks squat a lot. Airbags is a terrible way to raise the truck without a load lol
Diamondback
Midwest
Was given an AMPPRO AP4-CH41 to test my 6th Order box from a previous vehicle. So, if the weather holds out this weekend, I'll install and take to work Monday to show that AudioBuffs.
SColang22
renzo2213
I installed the RC 2” front leveling struts. Before install my truck measured 35.5” from ground to fender, after install 39.25” and 39.5”. Hopefully it settles quick because I hate the squat lol the rear is at 38.5”
Before:
After:
BiGJZ74
American Canyon, CA
Installed the timber grove airbags today. Took 57 minutes. I cannot say enough about these. Easy install. No cutting. Running them at 10psi unloaded. Had them up to 100psi leak checking with no issues. If you are looking at airbags check timber grove.
Noticed that you used 1/4" spacers on ur 3.5" lift. Can I see a pic of ur truck?
renzo2213
Rides fine. A little worse than stock but that’s expected from a lift and off-road tires
Add the RC 2” level strut and only put the top hat on it, not the spring loader. Your ride will be much smoother. I just installed the 2” level strut from RC and it’s a night and day difference from the stock struts, it glides ride over bumps
