Reverse Moaning Noise When Cold
Joeyp
Jersey Shore
Is anyone having an issue ( only in reverse when cold outside) when backing up? I kept having this moaning noise when backing up this winter...took into the dealer and they said there was a TSB for the rear calipers which they supposedly took care of. This morning when I backed up I still had the noise but it was as loud.
Am I missing something?
kapinallinen2
5thGenRams Supporter
Southern Maryland.
Had the TSB 05-001-19 done Tuesday. Brake caliber brackets, pads and new bolts.
Have not had a chance to drive it much since, remains to be seen if the noise is taken care of. rear brake.jpg
Mustangmike66
Are you in 4WD High when backing up?
Edwards
TX
Have not had a chance to drive it much since, remains to be seen if the noise is taken care of. View attachment 44243
Not sure of the TSB number but your fix doesn't look like mine did. I posted a picture here of what the caliper brackets look like. It did fix the squealing.
kapinallinen2
Southern Maryland.
They did the 05-002-19 on yours. Mine was the original fix. Fingers crossed...
Joeyp
Jersey Shore
Did your truck only do it when it was cold?
Edwards
TX
Yes. Only when backing out of garage first thing in the morning. I LOL'd when I first read of the "Chewbacca" noise but that perfectly described what I was hearing. I laughed again when I saw what they'd installed to fix it but it worked. ~6 months later and it's still gone. I'm almost at 22K miles on the truck now.
RamCares
Michigan
Hi kapinallinen2,
Please be sure to keep us updated. If you experience this concern further, we are more than happy to support you in addressing it.
Mark
RamCares
Joetorres112
Hi kapinallinen2,
Mark
RamCares
I have a Long horn 2019 it has been 5 times on the dealer, the noise in the breaks continues. they have change brake pads, Rotors and calipers. Every time there deliver my vehicle the noise stop life for 4 days then it begins again.
kapinallinen2
Southern Maryland.
Have they done TSB 05-002-19?
FirstimeRAM
I just brought mine in for this last Thursday. They said there was a bulletin out on it and ordered the parts. I have lost track how many times its been to the shop in the first year?
RamCares
Michigan
I'm very sorry to hear this, Joetorres112. Would you mind following up with us via private message to provide further details regarding your situation so that we may determine how to best assist you at this point?
Hi FirstimeRAM, if you are in need of any extra support while in service for this concern, please do not hesitate to reach out to us privately.
Mark
RamCares
