probably going to do the same setup after I purchase . Want 37s but will puss out .Are you planing on installing the Daystar 2" spacers upfront? That and the links should bring it back to stock ride quality. I'm going with Daystar/Links and 295/65/20, but that's a couple of months away
//g_svan
Part #KC09113BK less that $100 on eBayWhat is the part # for the daystar 2" and where to buy at a reasonable price.
Part #KC09113BK less that $100 on eBay(https://5thgenrams.com/community/threads/37s-with-only-a-level-oh-its-possible.7664/#post-112900)
//g_svan
What's the difference between the KC09113BK and KC09139BK?
Does anybody know if/ why the spacers wouldn’t work on a 2WD? Daystar say only for 4x4Here is my post from another thread that details my experience with the Revel links and the Daystar leveling kit. Also pics in every ride setting.
Tire/Wheel Dilemma for New Limited
My links differ as well - approx 10mm I'd say, and it doesn't worry meI have the daystar spacers and revel links on the front of my limited. I feel like something is wrong. I have the fender heights just about even but the driver’s side link is as short as possible and the passenger side link is as long as possible. This doesn’t seem right... Any help would be appreciated.
Id really like to see pics of where you are at now. I have the same setup and im kinda freakin about getting the tires without all kids of testing.I have now added the leveling links, no tools needed, half hour total including adjustments to get the ride height where you want it. Easiest to just remove completely adjust then snap back in. Need to make sure the new links are on completely, feels like two separate clicks. Have mine adjusted so back is 1/2 inch higher than front. No real diff to the ride, already running "E" rated tires...
With the ~ 34" duratracs, measurement to the top of the wheel wells on "normal" are as follows. Dropping to Aero lowers both by 1"
Front-39.5"
Back-40"
Probably not the best angle to show, but I had all four links put on. Been driving it for over two weeks now and no error codes or messages. I am running 35” BFG. In normal mode, I can sometimes have some minor rubbing at the furthest extent of the turn. Looks clean.
