SynAckuL
- Jan 5, 2019
2019 5.7L 4WD w/3.92 gears shifts horribly at low speeds. When in 1st and pressing slightly on the gas, the truck will jerk forward. When letting off the gas, it slows quickly causing a forward jolt. This happens all the way up to 4th gear. Highway speeds seem normal. My older vehicles (F150 with 6 speed, Jeep Wrangler 4 speed, Ford Fusion) do not shift this harshly, and I would have thought the 8 speed would actually be smoother.
If I could equate it to anything, it would be like a new driver of a stick shift revving the RPMs too high before letting off the clutch, or slamming in the clutch with the revs high before shifting.
Transmission valve body has already been replaced due to the park/drive issue.
Is this normal for this vehicle?
