travelerut
- Sep 14, 2018
Hey all,
So; my previous truck was a 2016 GMC - they all have factory LSD (as every car/truck ever made should! lol) but everyone has to save a buck. That being said, I've been loving my RAM minus a few early adopter hassles.
The gearing on this thing is great with the max tow package (3.92) - but you can count on always spinning one tire, even on dry roads, when you launch. In anything other than totally dry weather, may as well keep it in 4WD Auto. The truck has the Offroad package, so stock eLocker. This is mutually exclusive to the LSD. So, I called to local off-road shop to see if anyone made an LSD for this thing yet. Apparently yes, but with some caveats that I wanted to document for anyone else doing this. It's never come up, and I'd bet I'm the very first person to want this done. So Yukon (the maker of the aftermarket LSD) wanted all the notes as well because it's new to them.
The Yukon Dura Grip for 2011+ 9.25ZF rear end fits perfectly
Yukon Master Overhaul kit, performance ring & pinion gear set for 2011+ 9.25ZF also fits
The interesting bit, is that with the Max Tow package you apparently get 32 spline axles, which are 6 lug on the new body style. In all the other 1500's you get 31 spline axles - and that is what all the aftermarket LSD's I've been able to locate expect - 31 spline axles. So, they managed to lay hands on a set of 31 spline axles that they are being told are 6 lug. Haven't seen them yet - hopefully next week. So either they'll fit and we'll be good to go - or we'll have to fill in the 5 lugs and re-drill for 6 at a machine shop.
I'll update once we're done. Whatever done happens to be. Just wanted to make sure anyone else trying to add LSD to their 5th gen 1500 with Max Tow has an idea!
