I just checked and they are still listed for $49 for fender flares. Type in tecoom mud flap on amazon
That's what I get for posting before coffee... found them - I started w/Tecoom and ended up on a husky liner page w/o realizing it (they happen to use exactly the same photos haha)
$50 link above - might be getting a set!
The factory holes lined up well and no drilling is needed to hold them on but they provide a clip and screw to secure the inner bottom edge of the flap. Adding this other point of attachment really helps finish the job. Very easy to do and no holes where it would show if changed later...
Can you take a few photos behind the front tires? My Huskys are nice but rubbing in turns and I want to see if there’s any difference in layout.
I did take some photos but dont know how to post on this forum. Sent a pm to you for getting them to you.
Just drove it to work and plugged it in.
Had my 2019 Rebel for about a month and a half now and about 650 miles. Mods so far - black front grille RAM letters, black out skid plates, red painted brake calipers, Line-X premium spray bed liner, ExTang Encore Tonno cover, 35% Ceramic window tint (front sides only), K&N drop in air filter, replaced all interior, third brake light and cargo light bulbs with LED's, Mopar rear bed step, front and rear WeatherTech mud flaps, Go Rhino RB20 Running Boards with truck bed liner coating, Tuffy Security locking console insert box, and a few minor things here and there... Is there an end to all this madness?????
T,
Do you have any closeup shots of your calipers?
I just ordered the G2 paint and want to see how you went about it.
Thanks,
Neurobit
Just installed Diode Dynamics LED cargo lights and 3rd brake light. The only halogen lights on the limited are the cargo lights and the 3rd brake light and it just didn't fit with the rest of the lights on the truck being LED. The first picture is the original halogen cargo lights for comparison.
View attachment 41301View attachment 41302View attachment 41303
Actually... You still have work to do... :p
The vanity mirror lights are not LED either. I had to do those after swapping my cargo & third brake light.
Once you do that you’ll be truly done
I knew it was too good to be true. Thank you for the info(y)
No. Totally different and smaller.
Here you go:
They have two intensities. I went for the 24 lumens. Great quality.
Here you go:
Thanks for the link, I think I will go with the 24 lumens as well. Can't argue with DD quality.
@Neurobit is the lower glovebox LED for yall? That was the only other halogen (along with cargo and 3rd brake) that I found on my Laramie with sunroof.
  • Back
