jdmartin
Hey all!
I think my door panel might be misaligned, or maybe the door lock that goes through the panel is misaligned. I'm not sure, but when you unlock the doors the door lock button doesn't extend past the door trim, while on the passenger side it extends past the trim maybe half an inch? On the back doors, the lock extends past the door panel maybe an inch. It seems like they should all be high enough that you could push it down with your hand if you wanted to. But I can't figure out what it should look like. If all the door locks should be the same height, or if they're all different. The window belt trim seems right on my driver's door.
I'm not really sure if I care that much, but I don't want the panel to be maybe putting more stress on the door lock button than it should by blocking the button from coming up. I am going in for an oil change and tire rotation next month and if this thing is wrong I'll have it fixed then.
Thanks!
Thanks!
