Official Ivory White Tri-Coat Pearl Thread
I’m buying that hood to go on my Limited
Love that hood thrasherjosh has.
Here is my limited. I replaced the power steps with the wheel to wheel fixed steps. Installed Mopar mud flaps and flex bed cover. Installed Revel links to lower it (about 1”). Wheels were installed two days ago. They are reps 24x10 with 295x40 tires. Slight rubbing. Working on identifying the issue. Picture taken in exit/entry.
I have the exact same truck and want to put 24" rims on mine like you have but Im concerned with the "slight rubbing" part? Did you go somewhere to help you with the setup? Im not looking for anything offload just for styling. Could you have gone with a lower pro tire or would that be to poor of a ride? Ive been trying to figure all this out with the air ride too but its been tough. Curious to hear your thoughts. Cheers.
also curious where you got your rim and tires
Hi. The slight rubbing part is a small area of the inner wheel liner. Its not a big deal. I bent it back and that took care of it. I will need to heat the part to make it permanent or cut that area. No help with the sizing. Just researched what wheels would fit and choose the meatiest tire I felt I could fit for comfort, wheel protection, and the look I wanted. The ride comfort is still good. I don’t really have a complaint.
Here I is mine.
This just happened to my baby this morning...
Ouch. It’s sounds like the paint is easily damage up front. I have small nick up front as well. I used the paint pen to cover it up. Looks ok, hardly noticeable. Then I had PPF installed. I feel it’s a lot better protected.
Yeah I’m going to bring it up to the dealer as it doesn’t look like a rock chip to see what they say. I feel like the paint there is not applied right or something. I’ll figure it out. Get it fixed one way or another and then PPF it
Im looking for a 24" inch dub style low pro style set up. And ideas who I could go to to that could get it done right. Your truck is simply awesome btw I love that.
Where are you located? I can give you a few shops info in your area that are reputable
