Where did I complain about the price?That you spend all that $$$$ and then complain about gas
But $36k is different
Also, your welcomeView attachment 38575
Wyoming has "blue gas," which is ethanol free.Complaining at the pump is my god given american right.
pretty much in this priority order:
Ethanol content
price per gallon
octane rating
fuel door on the wrong side for the pump that I can reach today.
fuel tank too small, refilling too often.
fuel tank too large, can't afford to top it up.
Lovebugs.
Who took the squeegee from the washer bucket.
add to the list about how big corn is keeping us from having adaho's superior fuels!Idaho has "blue gas," which is ethanol free.
Oops! That should have been Wyoming, not Idaho. ID may as well but I have not seen it.
Hunt, fish, beautiful country. And not much else.What's there to do over there btw?
If it did Ram would require it in the owner's manual...so definitely not.
The original point I was making was, even with 85, there was no power or mpg loss.
Not true at all. They already give you a warning about it in the manual, but they're not forced to say "required" anymore then they're apparently not forced to make a distinction in EPA certified MPG between a light tradesman and a heavy limited or rebel.
Not true at all either. There is definitely a difference, the computer will be doing knock retardation and that means a decrease in power. You may not feel it, but it's there regardless. Others like myself definitely feel it under WOT or heavy loads, or even hilly highways. Remember, just because you might be color blind, doesn't mean that red doesn't exist.
To the OP of this thread; it costs you maybe 200 more per year to run the recommended octane, if you plan to keep the truck for a while then it seems like the smart thing to do would be to follow the recommendations of the guys who built the thing instead of penny pinching.
I do the exact same thing at costcoI'm sure you've probably considered it, but when I fill up at Costco, I blend the 91 with the 87 to get to 89, or close to it. Saves some $ and really no additional benefit to using all 91 that I am aware of.
I run 89. Gives you no “more” power, but insures the engine wont knock and pull timing. The higher the octane the more resistance to knock. Thats all it is. This way you get the full power i paid for.
I've used 89 for every fill-up since I got my truck last year. I have 17000 miles on it now. I use 89 just for the fact that the manufacturer recommends it. I'm sure they didn't just randomly recommend it, there has to be a reason. The fuel burns better at 89 and I'm sure it will have a long term positive impact to use 89 over 87. You may not see the benefits now, but you may see them down the road if you plan on keeping your vehicle for a long time.Haven't found an answer in the forum search.
Owners manual recommends 89 Octane, but says that 87 Octane is okay also.
Aside from a (potential) slight increase in performance, and possibly MPG - is there any DETRIMENTAL EFFECT to just sticking with 87?
Regards,
Rick
