Nitto Ridge Grappler VS BFG KO2
thrasherjosh
I have Ridge Grapplers on my JLUR Jeep and just put LT295x55x20 on my 2019 Limited. Love the tire and they are not noisy.
Sent from my iPhone using Tapatalkk
Do you have anymore pictures of your wheels! I just can’t make up my mind!
dakmary
I’m on my 2nd truck with ridge grapplers, and they are AWESOME! Both 1/2 tons. I’d maybe check out a lower load range if you are worried about sacrificing ride quality. I have load range E on both trucks and you can notice a decrease in the ride. Dry, wet, and snow traction is solid.
I’m interested in size 285x65R20 (or 35x11.5x20). I haven’t seen them in load range lower than E!
Clayssport
Only problem with ko2s is the tread life. 20km or 16k miles and i was under half tread. 7mm remaining.. i have 50km or 35k miles on duratracs and still at 11mm. To each there own.
Ram41313
Same here I love my duratracs
Pyleketerson
I wonder why there is such a discrepancy in tread life. My KO2’s have 20,000 miles and barely look used (haven’t measured tread depth). I do lots of highway driving and some off road dirt stuff on occasion. Expecting I’ll get 50,000 out of mine. I am starting to notice a little more road noise, though.
heydre
I am skeptical too for a couple reasons:
1. Measuring tread depth is janky at best (uneven wear, method?, inflation)
2. I've had 4 sets on 3 different trucks and got 40+k from all of them with on/off road use (generally 38-40 psi)
3. The length of time that passes, IMHO, always seems much shorter than what has actually passed (including mileage...have to refer to docs to get actuals)
sman301
For the guys with the Ridge Grapplers, how much of an mpg hit do you estimate you took coming from stock?
dakmary
I finally installed the the Nitto Ridge Grappler (285x65x20). I love the look. No rubbing at all. I wanted to get 35*12.5*20 but that would definitely rub.
In terms of comfort, it is very close to stock. HOWEVER, the Noise... It's very noisy in my opinion. Please tell me the noise will go or decrease very soon. Both my wife and daughter noticed the noise once we hit the highway. We had to turn on the radio to make it go!
Sent from my GM1913 using Tapatalk
Toothninja
San Antonio, TX
Love the look of your setup. I have used ridge grapplers and haven’t noticed much in the way of noise...but then again I’ve also used trail grapplers before and those are loud! Just different perspectives I guess...
a question for you though...what made you go with 285/65r20 and not 35/11.5r20? They are the same size...I’ve been looking into these tires and was wondering why one over the other. And what lift are you using?? Thanks! And looking good!!
dakmary
Well, it came down to 2 factors.
1- I was worried that the extra 0.3" or so in hight/width will cause the rub. I had these tires shipped all the way to me in Saudi Arabia, so returning them was not an option. Look wise, no one could tell them apart, even from a 12" distance.
2- This size was readily available by the seller, where for the 35*11.5 I had to wait TWO FULL DAYS :)
I have daystar and revel links (lifted the front by ~1.5 inches)
Toothninja
San Antonio, TX
That’s hilarious! Whenever I buy things nowadays, I am like what do you mean I have to wait until tomorrow. When back in the day, it was always 4-6 weeks or more! Lol!!
I was just trying to see if there was a specific reason for the LT tires over the non-LT.
Thanks!!
kittyjo
Is that Sheetz gas station!?!
Stickerhead
The Ridge Grapplers are noisier than a AT. I come from the Jeep world so mud terrain style tires don’t bother me. If you are looking for perfect quiteness, not your tire. I bought LT’s because a pull a car hauler with my Jeep. I want a good LT tire instead of that Goodyear Eagle that came with the 22’s.
dakmary
Not sure how I can describe the noise the tire makes.. But it's like a loud humming
dakmary
