HotHareSpey
- May 14, 2019
I understand how the engine works. I have been tuning PCMs/ECMs since like 2007.
Based upon the info provided to me, the engine will run fine on 87. The PCM may pick up a bit of knock, under extreme conditions (like my previously mentioned high-speed pass), and will retard the ignition timing a bit, to compensate.
It won't damage anything, although it may cause a minor loss of power. People who drive easily will likely never notice the difference, as the PCM will never go into "KR" (knock retard.)
As you said... buy whatever gas you deem necessary.
Since I tend to drive a bit harder than most, I will usually use 89, unless it's just stupidly expensive. But if I use 87, I'll just expect what I get.
Radar -
allow me to clarify that I didn’t mean that in a condescending manor. At all. I had to bone up on what the difference was just to be sure regarding this engine. And you likely know more than I do about it.
