Tailgate issues.
Hiimkyle70
Does anybody elses tailgate (electric handle and the tailgate damper) have issues opening their tailgates sometimes. Usually after not using it for a bit I have to hit the button and push the tailgate however after that it opens with just the button. Somebody told me they think it's a safety thing but I'm not quite sure
I have not had any issues with my tailgate.
No problems with mine either.
It works with the fob, the switch inside the cab, and a pull of the handle each time without issue.
For sure. Easy Easy fix though. Get a T-45 torx bit, loosen the passenger side tailgate strike post, move it toward the rear of the truck 1/16 to 1/8 inch and retighten. Takes about 30 seconds to accomplish. Tailgate will release every time with either push of the remote or tailgate handle, and you will not need to push forward on the tailgate to release. Also eliminates the "tailgate not closed" warning in the cluster.
Thank you. I'll try it tomorrow
Hello Hiimkyle70,
If you decide to have your dealer address your tailgate concerns and additional assistance is needed, you can reach out to us through private message.
Laura
Ram Cares
Mine was wonky when I first got my truck too. Couple shots of WD40 on the latches and normal usage now it’s working perfect. I think the latches stick bit if not used for a long period. You could hear the actuators working but it wouldn’t release. Lubed up the latches and good to go
