Readylift 3.5" Kit w/ 35x12.50x18.
ErnestRocks19
Has anybody done this setup yet? If you have I'd love to see some pics as 4wheelparts is saying they can do but all the lift kits are calling for 20" wheels. It comes with 18" stock on the bighorn just wondering what rubbing or cutting needs to be done if any.
I did a 2.5" Moto fab leveling kit with 35/11.50/r20 and had absolutely no rubbing.
I just purchased the Ready Lift 3.5" SST kit for my 2019 Ram 1500 Laramie 4x4 and got some Ridge Grappler 35x12.5x20's that are going on my stock 20x9 wheels. Getting it installed in a week and will post some pics.
Getting mine installed next week so I’ll let you know. Ready Lift says it will fit, store says it will rub. I guess only time will tell.
I just had some ko2 put on yesterday. Had slight rub on full lock reverse. Both directions. Keep in mind I had 1.5" wheel spacers installed also. I just went out to remove them and no rub. Any direction, full lock. So it will definitely work.
Well, what offset?
I've got the 3.5" SST kit and some Pro Comp A/T 35x12.50x18 being installed next week
would love to see some pics , i go back and forth with either going 20X10 or 18X9 . i like the 18x9 just becouse i would like to have more sidewall,
Well, what offset?
I would like to know the offset as well. I have 20x9 with I believe a +18 or 19. Like I said, Ready lift says 35x12.5x20 will fit with no problems so I am hoping they are right.
Pics yet?
Pics yet?
Picked it up today. So far, no issues. I've got about 1/2" to 3/4" of clearance by the upper control arm. It is really close on the inner fender at full lock so a little minor trimming may be necessary but I have only drive it about 30 miles and it feels great.
View attachment 33372View attachment 33373View attachment 33374View attachment 33375View attachment 33376View attachment 33377
Has anyone measured how high their truck is with this set up? Wondering if I will still be able to park in my garage at home and in the parking garage at work.
Not trying to high jack this thread but I just had the same lift put on. What size tire do you think would do best on the oem laramie 20" wheels?
The Nitto Ridge Grapplers 35x12.5x20 work fine on my truck. So far no issues
6’9” (81”) to the top of the antenna.
Don I'm doing a similar setup. How are your 3.21 gears handling the 35's? Also any noticeable improvement with the Hellwig? Thanks!
