Midnight1988
They are 285/65R20sIt looks really good. What was the actual tire size that you ended up getting? I tried to zoom in to look, but can't make it out.
Wow that looks perfect. Lift and tire size go perfectly. Nice job, for sure what I'm looking for as far as looks.
which brand tire did you go with ?
Yep, Daystar and home-made links. 2” up in front and maybe a half inch up in rear. Used 1.25” hubcentric spacers, which is the same as the -12mm offset you are interested in. You shouldn’t have any trouble with 35’s. Only issues are that I broke the front right sensor mount, I think it’s because the nuts weren’t completely tightened above the spacers by the shop. Currently trying to figure out how to modify off the shelf mud flaps so they don’t rub. Have a thread about it all out there somewhere - Journey Toward a Bigger Rebel
Yes looks awesome. Any rubbing issues with that size tire on that lift?i think so as well! It took me a long time to research and make sure it was what I wanted. Even when I was at the tire shop I was like man I hope this works. The moment I saw one tire go one I was like“”
Here’s the level:
But then you’ll want bigger rubber, at least 35 like JhRebel! these are 37, maybe a bit excessive
I haven’t had any issues. Even got under my truck today to show you the space I have. Hopefully it helps
Midnight1988,
With your level and larger tires, are you having any issues with features. Such as ACC or sensors. I am looking to do a level or all around 2 inch lift but I use my ACC regularly and don't want to make all the safety features or 1st world features unusable.
Thank you.
69Sting
I saw in the other thread about the rubbing issues? What was the cause of that?
I haven’t had any issues. Even got under my truck today to show you the space I have. Hopefully it helps.
I feel like the ride has definitely improved and feels smoother.Thanks for the images, nice to see that there is no rubbing at all. Hows the ride with the fox shocks, seem to change the ride at all? Last question!
Is this the updated kit? Looks sharp!
Thanks!!! I’m not sure tbh. I got it installed in July 2019.Is this the updated kit? Looks sharp!
Gotcha. I’m not sure when they updated the spacer so it’s hard to tell. I’m debating the lift but concerned about going to high. Any chance you’d be willing to grab some measurements? Center of wheel hub to fender front and back? Maybe a pic straight in from the side of you have time? I’d appreciate it, looks like the look I’m going for.Thanks!!! I’m not sure tbh. I got it installed in July 2019.
