E.Hands
Did anybody here get both the V6 and the 4-corner air suspension?
I was just going to point the OP to youYes. Why, what's up?
Wow! Tell me more. I'm trying to order a Laramie Longhorn w/V6 & A.S. but my dealer said FCA won't build it. What model do you have? Did you custom order it that way?Yes. Why, what's up?
Ok, I see you have a Longhorn as well. I'm really curious if you custom ordered it or not. And how much trouble it was for you.Yes. Why, what's up?
I custom ordered mine, it wasn't a problem at all. I didn't do the two-tone paint on mine, but I remember there being other people posting about ordering holds and delays for the two-tone paint a year ago when I ordered mine. There was a dealer on the forum last year who really helped me out by printing up an order sheet for me even though I wasn't going to order through his dealership, and then I just shopped that order sheet around to the local dealers that I wanted to pit against each other.Ok, I see you have a Longhorn as well. I'm really curious if you custom ordered it or not. And how much trouble it was for you.
I've been told by several dealers that the white w/brown bottom paint scheme was not available and that the V6 wasn't available in the Longhorn. Now I'm being told that the air suspension can not be had with the V6. Even though the configurator allows it.
Also I noticed your fuelly icon reads: 14.8MPG. Do you think a 2WD w/ 3.21 gears could achieve closer to the EPA's 20/25 MPG?
Thanks for your reply, You've got me really thinking about holding out for the V6 now! Is anyone with a V6 getting close to 25 MPG on the highway?Yes. Why, what's up?
Are you saying it gets worse MPG in town than it does on the open highway? How many miles do you have on it and what gear in the back end?My dad has had his 2013 RAM 1500 4X2 Tradesmen model for 6 years now and averages 21MPG and has had ONE issue the entire time he's owned it which was a simple fix by the dealership and wasn't expensive at all. With the great success hes had, I purchased a 2019 RAM Limited 4x4 with the V6 with every option available and although I'm only getting 16.5-17MPG city driving like a grandpa, the truck is so simple compared to my diesel and I love driving it. The MPG has let me down so far because I was expecting it to be as great as my fathers, but I'm hoping it gets better with time. On the highway I'm only averaging 15-16MPG going 80 with 1 passenger. My diesel got better miles per gallon honestly.
I personally have had no issues reaching the EPA 24 mpg highway on long drives and 21 mpg combined ratings. I documented a 140 mile highway trip where I sat in 40 minutes of traffic, and I still was able to average 25.3 mpg. For quick reference; Big Horn, 4x4, coil suspension, 3.21 axle ratio.Thanks for your reply, You've got me really thinking about holding out for the V6 now! Is anyone with a V6 getting close to 25 MPG on the highway?
I had a 2020 Longhorn 4x4 built by two different dealers 3 weeks ago. Negotiated and was ready to buy but also wanted to add the split tailgate. They could not order a Pentastar on any 2020 Ram 1500 a week ago Friday. Nor could they yet order the split tailgate. They said they expected more V6s to be released for order fist of September. They had no idea about the split tailgate.Wow! Tell me more. I'm trying to order a Laramie Longhorn w/V6 & A.S. but my dealer said FCA won't build it. What model do you have? Did you custom order it that way?
I was attempting to do the same. I really wanted a V-6 in my loaded Longhorn but they kept saying the standard engine wasn't available!?!I just tried a Longhorn on the configurator, and it won't add the air suspension without an upgrade to the V8. Total BS. We'll see when I actually try to order. But since I'm not crazy about the silly pinstripes and filagree of the Limited, that might be enough to flip me towards an SUV instead. Get it together, Ram.
Well that was it then. I couldn't understand why the air suspension was only available with the eTorque Hemi. I'll be ok if I can get close to the 23 MPG on the open highway rating although I am doubtful.I was able to build a Longhorn 4x2 just now with virtually everything and the V6. The only thing that required the v8 upgrade was the air ride suspension.
So yeah, no visible logic, I would think it is just another of the website glitches.
If you have access to specific fuel consumption curves for the Ecodiesel, Pentastar and Hemi please post them. I have unsuccessfully searchd to find them. I am awaiting delivery of a new Longhorn 4x4 Pentastar air suspension 5'7" Rambox to replace my current 2014 Ecodiesel Longhorn 6'4" regular box 4x4 air suspension regular box. The specific fuel consumption curves showing amoint of fuel consumed per hp at various RPMs is a great resource to understand what you should be able to achieve with an engine and should get around the personal driving style issues.The V6 is a fine engine. Other than towing a trailer, I doubt few people are ever at wide-open throttle (WOT) in normal use.
A few points on mileage:
1) Friction is your enemy. It turns energy into heat rather than mechanical work. Generally, lower engine speeds will have the lowest fuel consumption.
2) The highest efficiency will occur close to WOT at low engine speeds. Unfortunately, the transmission will probably assume at near WOT you want more power rather than more efficiency and rev the engine faster. Tthe contours are level of brake specific fuel consumption, a measure of energy per unit weight of fuel in gm/kWh. But the key is brisk acceleration doesn't hurt fuel efficiency. The goal after that is to minimize losses due to braking.
3) The brakes convert the energy stored in the moving mass of the vehicle and convert it into heat. Basically throwing it away. Watching traffic patterns and maximizing the use of aerodynamic drag and mechanical friction to slow the truck will conserve fuel. That energy will be expended anyway.
4) The eTorque mild hybrid is nice, but it is a shame they didn't drive the A/C compressor and engine water pump electrically. Maybe a future version. Anyway, the auto feature of the A/C will manage the compressor, blower, and recirculation to rapidly cool and efficiently maintain cabin temps on a warm day. Manually controlling them is nearly always less efficient.
5) Tire pressures and tire mass contribute to efficiency. That is probably why LT tires are few and far between on the Ram. Big diameter all-terrain tires are not fuel economy enhancer.
