What is the Minimum Ram Payload: A Contest with No Prize!!!
DavidNJ
Payload is often the limiting factor in towing. For a 10,000 pound trailer the tongue weight needs to be between 1000 and 1500 lbs. Add a couple of adults, some kids, and some luggage and that is a problem.
My dealer was sure the payload can be searched by VIN. For a Limited 4x4 with 5-7 conventional bed, 20" tires, non-eTorque Hemi, and panoramic sunroof the computer said 1840 lbs. However, the door jam sticker had a different story: 1398 lbs.
34024
No we went to a truck closer to my spec: Limited 5-7 4x4, RamBox, Tonneau cover (and the factory softcover is relatively light), eTorque Hemi, panoramic sunroof. It didn't have the multifunction tailgate which we want but did have 22" wheels which we didn't. The computer said 1780 lbs.; the sticker said 1268 lbs.
34025
Does anyone have a lower payload?
Wxgs333
My signature says all..... I have Retrax Tonneau installed so my truck actually can hold 1,0xx lbs practically.
Edwards
TX
@SpeedyV is the resident champion at 1069:
Edwards
TX
I'm at 1141 and you can see my config below.
DavidNJ
How did it get so low? The 33 gallon take added 60 lbs. of fuel. The ORG added 20 lbs in tires and maybe 35-50lb in skid plates. That could be 130 lb. of the difference. And still leaves 25 lost pounds unaccounted for.
1111 lbs. We are getting into passenger car territory here. This is a Camry:
34027
thabiiighomie
Cincinnati, OH
Sticker Payload Capacity: 1,447 lbs
Nerf Steps - 70.15 lbs
MudFlaps - 6.5 lbs
Tri-Fold Cover - 59.9 lbs
True Payload Capacity: 1,310 lbs
Naively thought I would get 1,840 lbs (per the order). You would think their computer system is sophisticated enough to compute payload (or at least an estimate/range) for your truck prior to ordering.
Edwards
TX
Go look at the tire and loading sticker thread - someone figured out the weight of almost every option.
SpeedyV
Ram Connoisseur
Fort Worth, Texas
At least until that $72K Longhorn with everything I’ve got PLUS the multi-function tailgate shows up here...
raven_DT
Welcome to the 1/2 (some 3/4) towing world...
Zeronet
Florida and West Virginia
33gal tank and added fuel is 73lbs more than the 26gal, more than 73 if the vehicle would have been equipped with the 23 gal tank as standard.
ORG is 119lbs. Full size spare tire, 1”lift, heavier shocks, heavier tires and skid plates.
J-Cooz
Mine is 1190. Limited 4x4 long bed with skid plates, 22" wheels, e torque. Curious how much the skid plates add as well as the long bed.
DavidNJ
From another forum, the same problem. Note that the starting point is 250lb higher so it leaves them higher.
I test drove a 2019 F150 Lariat 4X4 with a max tow package today and was disappointed to see that the payload capacity listed on the yellow sticker inside the door was only 16668 lbs. When I expressed disappointment that the payload capacity was less than we needed to tow a 25 foot Airstream the salesman told me that the yellow sticker just listed to payload capacity of the cab and showed me a brochure listing a payload capacity of 2030 lbs. Am I being lied to?
Question: Do all of the trucks under 1200 lb payload have RamBoxes and sunroofs?
Wxgs333
My VW GTI has 1050lb payload....higher than my truck with the tonneau cover installed:oops:
