Joker4L
okay okay ladies and gents! I have been reading about all these AC issues since I purchased my amazing truck last June 2018... My truck only had three issues since then which was the clunking noise when turning which I fixed myself, the center console squeaking when putting my arm on it which the dealer fix and finally the HK system amp being updated.....
As far as the AC goes, I always believed my system performed okay even in the Georgia heat but I decided for curiosity sake to buy a temp probe and check the temps and sure as F&*K the Driver side on MAX AC was 576 degrees at best when avg 90 plus degrees out while the passenger side was around maybe 48 degrees.
So I said why not try what everyone else is trying.... I went and purchased the same value KcRay used and installed it in about 5mins and lost maybe a drop of coolant in the process (zero mess to clean) I turned the value completed clockwise to close it and then opened it two full turns.
With the truck idling (no driving) and the outside temp at 91 Degrees the driver side vent immediately dropped to 48 degrees! After about 5mins it went even further down to 45 Degrees. The Passenger Side dropped as low as 42.5 degrees. This is all at idle in the driveway so I can only assume when driving on the freeway it might even get colder.
The cooler air can be noticed dramatically without a temp probe.. I had my wife jump in the truck and it was so cold she said F&*K this and got out lol. The added benefit is also the cooled seats are now very cold and its so niccceeeee!!!!
Total cost at the local O'Reilly was a whopping $17 big ones!
Thank you KcRay for this engineering discovery lol
