Air Llift 1000HD
Just installed my Air Lift 1000HD in-coil airbags. Decided against putting my Schrader valves exposed by my license plate. I mounted them in my Rambox instead beside the 110AC receptacle.
SpeedyV
Ram Connoisseur
Fort Worth, Texas
Just installed my Airlifter 1000HD in-coil airbags. Decided against putting my Schrader valves exposed by my license plate. I mounted them in my Rambox instead beside the 110AC receptacle.
Sounds like a great name for a 1000 HP special edition Power Wagon :)
JRinDFW
Great idea! Do you know whether the Schrader valves could've been routed through any of the existing holes in the license plate? I don't have Ramboxes, but did want to avoid drilling any holes that aren't necessary and visible to a passer-by.
Shanesrt8
I used one of my license plate holes to run the valve through. I did have to drill through the bumper plastic but is hidden with the tag mounted.
Juli_hoop
this is exactly what I want to do with my 2019 ram rebel, also has ramboxes. what airbags did you get? did you install yourself? I also plan on making something to store a small compressor in the rambox.
JRinDFW
Nice - this is just what I was hoping for! Thanks for posting. Any concern that drilling through the bumper voids warranty coverage?
Shanesrt8
nope. you are not affecting the mounting or structure of the bumper at all
swarggs
Pennsylvania
I installed these and mounted the valve behind the fuel door.
Sent from my SM-G960U1 using Tapatalk
Juli_hoop
Will these air bags (airlite 1000hd) work for a 19 Ram Rebel?
