Air Llift 1000HD
Just installed my Air Lift 1000HD in-coil airbags. Decided against putting my Schrader valves exposed by my license plate. I mounted them in my Rambox instead beside the 110AC receptacle.
Just installed my Airlifter 1000HD in-coil airbags. Decided against putting my Schrader valves exposed by my license plate. I mounted them in my Rambox instead beside the 110AC receptacle.
Sounds like a great name for a 1000 HP special edition Power Wagon :)
Great idea! Do you know whether the Schrader valves could've been routed through any of the existing holes in the license plate? I don't have Ramboxes, but did want to avoid drilling any holes that aren't necessary and visible to a passer-by.
I used one of my license plate holes to run the valve through. I did have to drill through the bumper plastic but is hidden with the tag mounted.
this is exactly what I want to do with my 2019 ram rebel, also has ramboxes. what airbags did you get? did you install yourself? I also plan on making something to store a small compressor in the rambox.
Nice - this is just what I was hoping for! Thanks for posting. Any concern that drilling through the bumper voids warranty coverage?
nope. you are not affecting the mounting or structure of the bumper at all
I installed these and mounted the valve behind the fuel door.
Sent from my SM-G960U1 using Tapatalk
Will these air bags (airlite 1000hd) work for a 19 Ram Rebel?
