Brain h
Hey guys..I'm having a lot of vibration issues with my 19 limited 2wd..I'm thinking to swap out the rear shocks (air suspension) but I cant find any aftermarket brands that are available...any ideas..thanks.
Been to the dealer 9 separate times... had the tires replaced with michelen's , road force balanced everytime..alignment. I have been told by my local tire shop that I have a warped wheel (that Chrysler refuses to recognize and refuses to replace ) but I want to change the shocks because that is the cheapest option I have right now and I at least want to eliminate them..the closest driveshaft shop to me is about 2hours away..but that is next.If you're having vibration issues, I would look at your rotating various assemblies - wheel/tire balance, brake rotors, or driveshaft before considering the shocks as the culprit.
Lol...unfortunately my vehicle is full of suprises...my spare is 18 inches and my wheels that are installed are the 22 inch..I dont really know if that makes a difference but I did just find this out just now...jesus..fiat.If you have a full-size spare, you can always swap that with the wheel you think may be bent and see if that is for sure the problem.
And he spare is a temporary unless you optioned up.Lol...unfortunately my vehicle is full of suprises...my spare is 18 inches and my wheels that are installed are the 22 inch..I dont really know if that makes a difference but I did just find this out just now...jesus..fiat.
There’s not even a chance it’s the shocks, seriously, none. This will be waste of money and time.
A better question is why do they think you have a bent wheel? How much weight do you have on said wheel?
There shouldn’t be more than like 2-3 ounces on any of your wheels, Anything higher would be highly suspect to me.
The wheel has been confirmed to be bent or out of round by two independent tire shops, but I've also been told that the shocks from the factory in the past were the wrong length and not up to par with the weight of the trucks..
Just waiting on my check from fca..they refused to replace the wheel even with evidence of the warp..I filed a lemon law suit and we have settled with a payout and i keep the vehicle with all warranties i pointed the issue out when the truck was purchased with 9 attempts at a fix between two dealers and a new set of tires..if a new wheel doesn't fix it I will be trading for a gmc..the customer service I received was horribleCan’t cause any vibrations, even if that’s true. It’s just not what they do, they simply handle controlling the weight transfer of the truck.
If that’s true about the wheel, I don’t understand why you haven’t replaced it. That’s the answer.
I understand they are expensive, so sell the other 3 and buy some aftermarket wheels and make a positive out of this.
