Novacain
- May 29, 2019
Has anyone had issues with the Electronic stability control light illuminating after 2000K and have a confirmed fix for it?
I called the dealer as soon as the light came on because it was just as I was leaving the dealer after getting my speedometer recalibrated for bigger tires.
they told me at the time it wasn't from recalibrating but it was because I was towing a trailer.
also shortly after at the ESC light the check engine light came on at 4800K with the code P0258B-00, brake booster vacuum pump.
1st attempt to fix the dealer flashed the ECU. they said there was a TSB to flash for the problem.
on the way home 10K from the dealer ESC light came back on but no check engine light, so turned around & wen't back to dealer.
2nd attempt, they now determined it was the vacuum pump to be defective, ordered the pump and put me in a rental.
today they called me and said, your good to go. the problem has been fixed so I go pick it up. I see they put almost 20K of test drive on it then I get 4 blocks further then the last time and BING, BING, ESC lights up. I call the dealer and tell them it came back on.
3rd attemp hasn't happened yet
