Difficulty Starting after Fueling
Brodiemac
Hi All,
Over the past few weeks every time after i fuel up the truck doesn't seem to want to start. It usually take 2-3 engine cranks before it actually catches. It only happens after fueling and just one single time until i fuel up again. Its been to dealership several times with EVAP codes appearing but they have yet to solve the issue. The Vent valve was also replace with no luck. Any ideas on what this may be?
2019 RAM
10,000 Miles
Brodie
RamCares
Michigan
Hi All,
2019 RAM
10,000 Miles
Brodie
Hi Brodiemac,
I certainly understand why this would be concerning. Given your situation, I would be happy to escalate a case on your behalf. What this does is allow our team to formally document your concern, as well as connect you with a Case Specialist who can work alongside your dealer to find a potential solution. Simply follow up with me via private message if this would be of interest.
Mark
Ram Social Care Specialist
Brisoup1
Hi All,
2019 RAM
10,000 Miles
Brodie
My dad had a Ford Contour and it would do the same exact thing. It ended up beign a bad fuel pump. The fuel pump was on top of the fuel tank.
