I don't have my truck yet to even see if this is possible but I dreamed this mod up on my current ride. The Ram has ventilated seats, not AC cooled seats. So why don't we make them AC seats? It's hot in Texas!
Since Ram so thoughtfully ran AC vents through the center console, and bragged about more rear airflow, it's just asking to be partially diverted for a higher purpose.
My thought is to cut a hole into the side of the console low under the front seat so that cold air now blows out. Then run some hose from there up into the seat air intake - you could also cut a small hole in the hose so your under seat amp gets a drink.
Since the seat is tall and close to the console, you'd never see your mod either. I'm still wondering if a valve wouldn't be desired as this would run heated air in the winter but some of you in the north might enjoy it!
The next step is to figure out if the console ducts are on the outside of the console like I imagine they are and then pretending I know anything about fluid dynamics to determine what size hole/tubing to balance rear air and not freezing myself out.
