33950 WESTERN MOUNT 2019+ DODGE RAM 1500 ULTRAMOUNT
I purchased the truck mount and plug and play wiring harness from:
Storksplows.com
Phone #610-488-1450
The mount was a perfect fit and the wiring harness for the LED lights was truly plug and play. received within two days of placing the order. The sales rep Anna was very friendly & knowledgable. I highly recommend Storks Plows to everyone.
The only difficulty was the removal & re installation of the front bumper. Ram added a piece of rubber between the upper portion of the bumper and the lower grill area of the truck.
To remove the bumper the only thing that needs to be removed to get it off of the truck are the six R & L bumper bolts, and the large multi pin plug located on the driver's side between the front bumper and driver's side wheel area. Once those have been removed you will have to pull firmly on the bumper to remove it and also to re install it. In regards to everything else simply follow the provided instructions.
Storksplows.com
Phone #610-488-1450
